查看: 1219|回复: 4
有一台电脑运行出现下面错误
发表于 2025-8-29 16:57:48 | 显示全部楼层 |阅读模式
老版本的时候没问题
发表于 2025-8-29 20:31:17 | 显示全部楼层
点击定位到文件 压缩上传最近的两个文件
 楼主| 发表于 2025-8-31 08:14:22 来自手机 | 显示全部楼层
从官网又下载了一遍又没问题
 楼主| 发表于 2025-8-31 20:27:35 | 显示全部楼层
错误如下,偶尔还是会出现
Microsoft (R) Windows Debugger Version 6.12.0002.633 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Users\Administrator\AppData\Local\Temp\com.everauto.ztasker\37d724723288bc358f1d354e458c49bf_1510888468.dmp]
User Mini Dump File: Only registers, stack and portions of memory are available
WARNING: Minidump contains unknown stream type 0x15
WARNING: Minidump contains unknown stream type 0x16
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path.           *
* Use .symfix to have the debugger choose a symbol path.                   *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
Windows 7 Version 26100 MP (8 procs) Free x86 compatible
Product: WinNt, suite: SingleUserTS
Machine Name:
Debug session time: Sun Aug 31 20:23:22.000 2025 (UTC + 8:00)
System Uptime: 17 days 11:41:31.708
Process Uptime: 0 days 0:00:13.000
This dump file has an exception of interest stored in it.
The stored exception information can be accessed via .ecxr.
(388c.2a60): Access violation - code c0000005 (first/second chance not available)
eax=00000000 ebx=00000000 ecx=00000000 edx=01321878 esi=761ae770 edi=000004c4
eip=77c1992c esp=00faabe0 ebp=00faac4c iopl=0         nv up ei pl nz ac po nc
cs=0023  ss=002b  ds=002b  es=002b  fs=0053  gs=002b             efl=00000212
Unable to load image C:\Windows\System32\ntdll.dll, Win32 error 0n2
*** WARNING: Unable to verify timestamp for ntdll.dll
*** ERROR: Module load completed but symbols could not be loaded for ntdll.dll
ntdll+0x7992c:
77c1992c c20c00          ret     0Ch
发表于 2025-9-2 12:05:36 | 显示全部楼层
请按照置顶帖,上传日志和报告文件
https://bbs.everauto.net/forum.p ... &extra=page%3D1
GMT+8, 2026-11-9 00:35 , Processed in 0.053709 second(s), 24 queries .
