查看: 1090|回复: 1
2.15版本如果脚本有参数就会报找不到文件的错误.如果没有参数就没有问题.
发表于 2025-4-15 10:41:17 | 显示全部楼层 |阅读模式
[2025-04-15 10:40:19:367] .......热键执行开始...... <简单任务:运行Python脚本, 序号:60, ID:134>
[2025-04-15 10:40:19:367] 运行 <简单任务:运行Python脚本, 序号:60, ID:134>
[2025-04-15 10:40:19:368] .......热键执行结束...... <简单任务:运行Python脚本, 序号:60, ID:134>
[2025-04-15 10:40:19:399] 已获取输出:test
[2025-04-15 10:40:19:399] 命令结果:test
[2025-04-15 10:40:19:399] 简单任务执行完毕! <简单任务:运行Python脚本, 序号:60, ID:134>
[2025-04-15 10:40:19:399] <UITrayProxy::OnEvent> RunningTaskCount==0, Stop tray animaiton...
[2025-04-15 10:40:22:722] <CLogWnd::LoadLog> logFile:V:\zTasker_2.1.5_绿色版\User\Logs\2025-04-15.log
[2025-04-15 10:40:22:723] <CLogWnd::LoadLog> logFile size:715
[2025-04-15 10:40:22:723] <CLogWnd::LoadLog> logFile decoded size:525
[2025-04-15 10:40:28:411] <CTaskEditWnd::InitControl> TaskEdit InitControl begin
[2025-04-15 10:40:28:411] <CTaskEditWnd::initUISounds> TaskEdit Get TTS
[2025-04-15 10:40:28:412] <CTaskEditWnd::initUISounds> TaskEdit Get TTS tokens size:2
[2025-04-15 10:40:28:412] <CTaskEditWnd::selectTaskPage> Edit to Show subctrl is 弹窗提醒
[2025-04-15 10:40:28:412] <CTaskEditWnd::initUISch> TaskEdit Init battery detecter
[2025-04-15 10:40:28:413] <CTaskEditWnd::InitControl> TaskEdit InitControl end
[2025-04-15 10:40:28:421] <CTaskEditWnd::selectTaskPage> Edit to Show subctrl is 运行Python脚本
[2025-04-15 10:40:31:981] <CTaskEditWnd::SaveTasker> 保存任务开始
[2025-04-15 10:40:31:982] <CTaskEditWnd::saveUIAuto> Save task ui control:edtPyFile
[2025-04-15 10:40:31:982] <CTaskEditWnd::saveUIAuto> Save task ui control:edtPyVar
[2025-04-15 10:40:31:982] <CTaskEditWnd::saveUIAuto> Save task ui control:edtPyParam
[2025-04-15 10:40:31:982] <CTaskEditWnd::saveUIAuto> Save sch ui control:cmbEveryMin
[2025-04-15 10:40:31:983] <CTaskEditWnd::saveUIAuto> Save task ui control:edtPyScript
[2025-04-15 10:40:31:983] <CTaskEditWnd::saveUIAuto> Save sch ui control:edtEveryMin2
[2025-04-15 10:40:31:983] <CTaskEditWnd::saveUIAuto> Save sch ui control:chkResetTimeWakeMin
[2025-04-15 10:40:31:983] <CTaskEditWnd::saveUIAuto> Save sch ui control:chkResetTimeStartMin
[2025-04-15 10:40:31:984] <CTaskEditWnd::saveUIAuto> Save task ui control:cmbPyEnv
[2025-04-15 10:40:31:984] <CTaskEditWnd::saveUIAuto> Save task ui control:chkPyVar
[2025-04-15 10:40:31:984] <CTaskEditWnd::saveUIAuto> Save task ui control:OptPyFile
[2025-04-15 10:40:31:984] <CTaskEditWnd::saveUIAuto> Save task ui control:edtPyWaitTime
[2025-04-15 10:40:31:984] <CTaskEditWnd::saveUIAuto> Save sch ui control:edtEveryMin
[2025-04-15 10:40:31:984] <CTaskEditWnd::saveUIAuto> Save sch ui control:chkResetTimeUnlockMin
[2025-04-15 10:40:31:985] <CTaskEditWnd::saveUIAuto> Save task ui control:OptPyScript
[2025-04-15 10:40:31:985] <CTaskEditWnd::saveUIAuto> Save task ui control:cmbPyExec
[2025-04-15 10:40:31:985] <CTaskEditWnd::saveUIAuto> Save task ui control:chkPyWait
[2025-04-15 10:40:31:985] <CTaskEditWnd::saveUIAuto> Save sch ui control:chkResetTimeBootMin
[2025-04-15 10:40:31:985] <CTaskEditWnd::saveUIAuto> Save task ui control:chkPyClip
[2025-04-15 10:40:31:986] <CTaskEditWnd::saveUIAuto> Save task ui control:chkPyAdmin
[2025-04-15 10:40:31:986] <CTaskEditWnd::saveUIHotkeyPage> Save hotkeys
[2025-04-15 10:40:31:987] <CTaskEditWnd::SaveTasker> 保存任务结束,耗时0ms
[2025-04-15 10:40:31:987] <CTaskEditWnd::saveUIHotkeyPage> Save hotkeys done
[2025-04-15 10:40:31:987] <CTaskEditWnd::SaveTasker> Send tasker edit notfiy: 134
[2025-04-15 10:40:31:988] <CTaskData::SaveTask> ModChildElem开始
[2025-04-15 10:40:31:988] <CTaskData::SaveTask> ModChildElem结束,耗时0ms
[2025-04-15 10:40:31:988] <CTaskData::SaveFile> SaveFile开始
[2025-04-15 10:40:31:990] <CTaskData::SaveFile> SaveFile结束,耗时16ms
[2025-04-15 10:40:32:002] <CTaskEditWnd::OnFinalMessage> delete self
[2025-04-15 10:40:32:003] <CTaskEditWnd::~CTaskEditWnd> Try _CloseTemTasker
[2025-04-15 10:40:32:003] <CTaskEditWnd::~CTaskEditWnd> clear time ctrls
[2025-04-15 10:40:33:784] .......热键执行开始...... <简单任务:运行Python脚本, 序号:60, ID:134>
[2025-04-15 10:40:33:785] .......热键执行结束...... <简单任务:运行Python脚本, 序号:60, ID:134>
[2025-04-15 10:40:33:786] 运行 <简单任务:运行Python脚本, 序号:60, ID:134>
[2025-04-15 10:40:33:821] 已获取输出:D:\Program Files\Python312\python.exe: can't open file 'E:\\data01\\Codes\\vscode\\python\\TestCode\\testcode1.py 1111': [Errno 2] No such file or directory
[2025-04-15 10:40:33:821] 命令结果:D:\Program Files\Python312\python.exe: can't open file 'E:\\data01\\Codes\\vscode\\python\\TestCode\\testcode1.py 1111': [Errno 2] No such file or directory
[2025-04-15 10:40:33:822] 简单任务执行完毕! <简单任务:运行Python脚本, 序号:60, ID:134>
[2025-04-15 10:40:33:822] <UITrayProxy::OnEvent> RunningTaskCount==0, Stop tray animaiton...
发表于 2025-4-15 22:09:17 | 显示全部楼层
已确认,感谢反馈!
GMT+8, 2026-11-9 01:30 , Processed in 0.101688 second(s), 20 queries .
