查看: 235|回复: 1
zTasker睡眠显示器后无法唤醒!
发表于 2026-9-18 14:00:54 | 显示全部楼层 |阅读模式
最近出现长时间睡眠后无法唤醒,我设置的是11:58分显示器睡眠,13:30分鼠标键盘都唤不醒现象,只能重启。日志是这样的:
[2026-09-18 11:58:00:974] SetNextRunTime begin, ID:403
[2026-09-18 11:58:00:974] SetNextRunTime end:2026-09-19 11:58:00, ID:403
[2026-09-18 11:58:00:974] TaskManager准备运行任务 <简单任务:睡眠显示器, 序号:7, ID:403>
[2026-09-18 11:58:00:974] TaskManager TryShowTipDlg <简单任务:睡眠显示器, 序号:7, ID:403>
[2026-09-18 11:58:12:031] 运行 <简单任务:睡眠显示器, 序号:7, ID:403>
----------简单任务开始执行----------ID:403
----------简单任务执行完毕!----------ID:403
[2026-09-18 11:58:12:031] Send Event EVENT_TASK_STAT
[2026-09-18 11:58:12:031] Send Event EVENT_TRAY_TASK_DEC
[2026-09-18 11:58:12:031] RunningTaskCount==0, Stop tray animaiton...
[2026-09-18 11:58:12:031] Save开始
[2026-09-18 11:58:12:031] Save结束,耗时16ms
[2026-09-18 11:58:12:031] WARN:警告: 检测任务时间过长,您的电脑可能CPU占用过高,不影响任务运行,但会影响任务执行时间的准确性和运行效率
[2026-09-18 11:58:12:433] System monitor off!
[2026-09-18 12:03:40:399] WARN:System locked
[2026-09-18 12:57:00:658] System monitor on!
[2026-09-18 12:57:04:897] System monitor off!
[2026-09-18 12:57:10:336] System monitor on!
[2026-09-18 12:57:11:545] System monitor off!
[2026-09-18 12:57:12:955] System monitor on!
[2026-09-18 13:00:14:016] System monitor on!
[2026-09-18 13:00:29:091] System monitor off!
[2026-09-18 13:31:09:458] System monitor on!
[2026-09-18 13:32:57:821] Main facade create
[2026-09-18 13:32:57:834] create unify
[2026-09-18 13:32:57:850] Init UI
[2026-09-18 13:32:57:850] OS ver>=win10, setting native dpi aware...
[2026-09-18 13:32:57:850] Set native dpi aware successfully!
[2026-09-18 13:32:57:850] Set UI LIB option
[2026-09-18 13:32:57:851] create db
[2026-09-18 13:32:57:851] sysini init
[2026-09-18 13:32:57:851] Main App init, appid:8772, appver:2.3.12, system:Windows 10 Enterprise X64 ( build 19041), path:C:\Users\Administrator\AppData\Local\zTasker\, cmdline:-m -autorun
[2026-09-18 13:32:57:851] Boot alerady:27秒 (2026-09-18 13:32:30)
[2026-09-18 13:32:57:851] Check only one instance and try pop last main window, appid:8772
[2026-09-18 13:32:57:851] Init Frame, popMainWnd=0
[2026-09-18 13:32:57:852] Insure ahk env
[2026-09-18 13:32:57:852] Set version
[2026-09-18 13:32:57:852] OleInitialize
[2026-09-18 13:32:57:852] AsyncTask init
[2026-09-18 13:32:57:852] Create main frame window
[2026-09-18 13:32:57:853] CEverTask Create
[2026-09-18 13:32:57:853] Total task types:304
[2026-09-18 13:32:57:853] CMainFrameWnd InitWindow
[2026-09-18 13:32:57:854] UI Proxy init
[2026-09-18 13:32:57:854] on init
[2026-09-18 13:32:57:854] Load Tasks File Begin
[2026-09-18 13:32:57:960] Load Tasks File End
[2026-09-18 13:32:57:963] Parse Tasks Begin
[2026-09-18 13:32:57:980] Parse Tasks End
[2026-09-18 13:32:57:981] 清理备份任务文件开始
[2026-09-18 13:32:57:983] Add Task to UI Begin
[2026-09-18 13:32:57:984] MemConfig init
[2026-09-18 13:32:58:109] Add Task to UI End
[2026-09-18 13:32:58:116] 清理备份任务文件结束,耗时219ms
[2026-09-18 13:32:58:663] System monitor on!
[2026-09-18 13:32:58:780] MBID:
[2026-09-18 13:32:58:782] HDID:0025_3885_01C9_9FEB.
[2026-09-18 13:32:58:789] MID:0025_3885_01C9_9FEB.
[2026-09-18 13:32:58:790] 异步加载拼音缓存开始
[2026-09-18 13:32:58:917] ApplyCfg
[2026-09-18 13:32:59:163] LoadStat
[2026-09-18 13:32:59:177] ERROR:Task has been deleted.
发表于 2026-10-20 19:50:41 | 显示全部楼层
zt应该是被冻结了,具体原因未知
日志里显示:您的电脑可能CPU占用过高,不影响任务运行,但会影响任务执行时间的准确性和运行效率
你可以谁占用cpu很高,从这里着手
GMT+8, 2026-11-9 00:18 , Processed in 0.062319 second(s), 21 queries .
