楼主: 861131477
2.0新功能使用反馈情况
 楼主| 发表于 2024-12-26 15:09:26 | 显示全部楼层
[2024-12-26 15:08:11:904] <CLogWnd::LoadLog> logFile:D:\http\zTasker_1.99.8_绿色版\User\Logs\2024-12-26.log
[2024-12-26 15:08:20]TaskManager准备运行任务 <简单任务:运行cmd命令, 序号:11, ID:288>
[2024-12-26 15:08:20]运行 <简单任务:运行cmd命令, 序号:11, ID:288>
[2024-12-26 15:08:29]命令结果:E:\project\backups\isaccese.py:27: SyntaxWarning: invalid escape sequence '\p'
  with open('E:\project\\backups\sensor01.json', 'r', encoding='utf-8') as f:
处理传感器 ID: 4588892
Traceback (most recent call last):
  File "E:\project\backups\isaccese.py", line 170, in <module>
    "Authorization": f"Bearer {get_access_token()}",
  File "E:\project\backups\isaccese.py", line 132, in get_access_token
    save_access_token(access_token)
  File "E:\project\backups\isaccese.py", line 113, in save_access_token
    with open(token_file_path, 'w') as file:
PermissionError: [Errno 13] Permission denied: 'access_token.txt'
[2024-12-26 15:08:29]简单任务执行完毕! <简单任务:运行cmd命令, 序号:11, ID:288>
 楼主| 发表于 2024-12-26 15:11:33 | 显示全部楼层
处理传感器 ID: 4588892
GMT+8, 2026-11-9 01:10 , Processed in 0.136253 second(s), 21 queries .
